Progress on Phil Lardner's All-carbon CD? 09 Mar 2018 18:44 #1088
New video - Covering the Wings using Stewart Systems 1.8oz SuperFlite Polyester Dacron and their EkoClean / EkoBond products.
I'm nearly finished converting my garage into a spray shop and hope to get the flight surfaces painted as soon as the air temperature rises a bit - the EkoPoly 2-part paint needs a minimum of 65-75°F to cure. Watch this space!
The following user(s) said Thank You: Don B, Valerii Ivantsov, Jeff Johnson
Progress on Phil Lardner's All-carbon CD? 29 May 2018 22:11 #1099
Aviation is imminent!
This test hop, using 4 out of 6 bungee ropes worked well, but the next run, using all 6 bungees revealed a problem - I couldn't open / release the rear anchor mechanism under the increased load. I will have to redesign the anchor release before I can take the test hops any further.
Last edit: by Phil Lardner.
Progress on Phil Lardner's All-carbon CD? 29 May 2018 23:25 #1100
Beautiful, fantastic, did you use the original tow release design on the tail?
Progress on Phil Lardner's All-carbon CD? 30 May 2018 00:30 #1102
I don't know how you resisted taking a couple short hops. I'm looking forward to the first flight video and reports!
Progress on Phil Lardner's All-carbon CD? - Page 15 - Jim Maupin's Gliders
Progress on Phil Lardner's All-carbon CD? 30 May 2018 08:12 #1104
Cheers Don!
Yes, I copied the tow release and used it for the rear glider anchor release, but the bungee pressure proved too much and I damaged the release handle, pulling the cable ferrule out of its mount in the cockpit.
Progress on Phil Lardner's All-carbon CD? 30 May 2018 16:33 #1107
Great Phil! The bird looks beutifull! Pitty about the release. The one you drew will work I think, but only as a retainer. One can buy these sort of releases in a marine store. Used one like that on my hangglider in the early days.
