Powered Aluminum Dragon (Part 1) 28 Apr 2016 23:30 #962
working on horizontal stabilizer...I formed the leading edge using the vacuum method, works well. shown here is 1/2 LE.
Last edit: by Don B.
Powered Aluminum Dragon (Part 1) 13 May 2016 01:26 #963
Leading edge 2 halves horizontal stabilizer being spliced.
Powered Aluminum Dragon (Part 1) 30 May 2016 22:07 #971
Improved rib assembly fixture.
Powered Aluminum Dragon (Part 1) 12 Jun 2016 02:21 #975
Horizontal stabilizer and elevator. Final finish of the ribs not drilled until line up at this step. That's why all the clamps
Powered Aluminum Dragon (Part 1) 23 Jun 2016 23:25 #976
Drill Guide, dimple with pop rivet tool
Powered Aluminum Dragon (Part 1) 28 Jun 2016 16:46 #977
Horizontal Stabilizer done except for fabric. Weight of 4.7 lb. which when added to the weight of the elevator of 3.4 lb = 8.1 lb. The original wood horizontal tail weighed 8 lb. Stay tuned for the load test to limit of 12 #/sq ft.
