The wings were leveled up spanwise and then tilted to 10° to simulate a pitch-up manoeuvre. Each side of the wing was loaded up with 251kg (553lbs) of sand bags (502kg / 1106lbs in total) while supported by the car jacks at the wing tips - with the following load out:
Wing Panel Panel Load
Rib 1 - 2 65.64lbs 29.77Kg
Rib 2 - 3 62.08lbs 28.16Kg
Rib 3 - 4 58.52lbs 26.55Kg
Rib 4 - 5 54.96lbs 24.93Kg
Rib 5 - 6 51.40lbs 23.32Kg
Rib 6 - 7 47.85lbs 21.70Kg
Rib 7 - 8 44.29lbs 20.09Kg
Rib 8 - 9 40.73lbs 18.48Kg
Rib 9 - 10 37.17lbs 16.86Kg
Rib 10 - 11 33.61lbs 15.25Kg
Rib 11 - 12 30.06lbs 13.63Kg
Rib 12 - 13 26.50lbs 12.02Kg
Total: 552.81lbs 250.76Kg
In the last two photos you can see that the lower spar cap (actually the top spar cap, but the wing is upside down) has buckled in compression *right on the centre line*. There is no other apparent damage visable to the wing, which leads me to believe that the wings can be fairly easily repaired.
The centre section of the wing spar (between the two #1 ribs) comprises two horizontal load transfer bars of solid carbon (5mm thick x ~25mm deep x ~420mm wide). Two more load transfer bars (similar dimensions, but shorter) run vertically, to which the pod/wing connection fittings are bolted. The space in between these four solid carbon bars is filled with 5mm foam board, covered by several layers of carbon cloth. This centre section shows minor damage.
The spar cap flanges between the two #1 ribs is only 10mm deep and is, in painful hindsight, woefully too narrow to carry the loads unsupported by the leading edge. I think that by bolting a pair of 10mm x 50mm x 420mm thick aluminium plates fore and aft of the spar cap under compression that this should make this section of the spar caps much more able to resist compressive buckling. The other spar cap (under tension) showed no signs of any damage, but I plan to reinforce it with a single, similar aluminium plate just in case!
I hope to have the repairs made and aluminium plates installed by Tuesday and will re-test the wing again. Fingers crossed!
