Powered Aluminum Dragon (Part 1) 20 Mar 2016 17:17 #955
Hinge and alignment.
Last edit: by Don B.
Powered Aluminum Dragon (Part 1) 24 Mar 2016 02:16 #956
Riveting .... splice and doublers on LE skin. Needed to hold in proper shape for the holes to line up.
Powered Aluminum Dragon (Part 1) 27 Mar 2016 05:54 #957
Finished riveting, weighs 3.42 lb, little heavier than I wanted, but very stiff. Next the loading to Limit....Stay tuned.
Powered Aluminum Dragon (Part 1) 29 Mar 2016 17:27 #958
Limit load test of elevator. Per "Faa Basic Glider Criteria" 12 #/sq ft. = 92 Lb. Uniform distribution span wise. The weights sit at the centroid of the ribs. This includes the gust loads. Elevator is mounted as it would be in the aircraft, from the hinges and control horn. Result...no deformation, usable part.
Powered Aluminum Dragon (Part 1) 07 Apr 2016 02:08 #959
Got my airspeed indicator today...Hall Wind Meter 0-80 MPH ....tested it with the car and it works pretty good.
Figured I would use it as a sure thing for initial flights.....its hard to know if a standard indicator is good because of negative or poor static pressure issues. I would be interested to know what anyone else is using considering the stall is supposed to be 19 mph.
Powered Aluminum Dragon (Part 1) 12 Apr 2016 21:47 #961
Quick sketch of engine and revised pod structure. Very preliminary drawing. That is a really small engine.
