Hi all,
I did some hangar talking in the glider pilots community and I had confirmation that one possible practical solution could be a FES ( Front Electric Selfsustaining) type of installation with the electric engine placed in the nose of CD and the battery pack behind the pilot so making CG original position unchanged.
For the sake of knowledge how far the electric power reality is coming in the soaring field see
www.front-electric-sustainer.com/index.php
The way that a FES is used on the Silent, or on other glider application accomplished as retrofit kit, is to keep the tail down during the take off and landing operation, you never level off with the landing gear wheel touching the ground. As soon as you lifted off you can reduce the angle and climb or fly leveled clear of the ground .Visibility in take off is normally affected on some gliders because of the nose high attitude ,which will be not the case on the CD because you have large windshield down to the front cone.
I did some sketches on the CD and to me, by increasing the wheel diameter to 400 mm, you can get acceptable prop clearance to adopt a 1.3 meter prop. This will allow the use of HPD 13.5 engine with one only battery pack of 40Ah weighing 16 kg.
I need to do some more investigation on HPD engine installation and on take off distances, but unless I made an error,this installation is feasible.
Weight breakdown could be
Empty basic 65 kg
Balistic 5
Engine kit 30
Total 100
Dream is getting closer.
Regards
Cesare
