Welcome,
Guest
Here is the load test, glad when it is done and nothing broke. 232 lb total which works out to 95.5 on the elevator, and 139.5 on the stabilizer. 12 #/sq foot per FAA Glider Criteria. It was mounted as would be in the aircraft, resting on the stab attach fittings and the horn blocked for the elevator. The rear spar is strong enough to support the fully loaded elevator.
