Hi Bertrand,
Welcome to the group! Careful study of the plans will reveal a number of minor discrepancies, most of which are documented somewhere in the documents on this site. The one that fools most people is where the plans specify 8mm plywood in various places... which is in fact supposed to read 0.8mm (1/32") ply!
As for the wing dimensions, Stick to 60" at the root and 22" at the tip. You can find an analysis of the wing dimensions, loads and stresses in my spreadsheet here:
www.ihpa.ie/carbon-dragon/index.php/cd-b...wing-stress-analysis.
Roger Hardie in South Africa is also starting work on analyzing the drawings and has produced a set of CAD drawings which might be of use. If he doesn't respond to this post, you can contact him through the list of registered users (Main Menu - Login - Registered Users).
I'm very envious of you and Roger with your CNC set-up - it would have saved me *many* hours of work cutting out the rib molds and foam cores!
By the way, if you are going to use a CNC machine to cut out your molds then you should investigate making them out of a material that will not sitck to epoxy (like HDPE or similar). The MDF molds I used worked well but are delicate and have their limitations! Again, Roger has been working on a set of CAD drawings for the rib molds.
Good luck with the project, and don't hesitate to ask questions!
PS - I'll print out and compare your rib drawings over the weekend and see how they compare to the originals...
