Cheers Gus! It certainly was a lot of fun to fly, and I'm really looking forward to next summer when I can settle in to flying it properly and hopefully take it XC in the Alpes.
I weighed all the various parts of the glider just before spray painting, and it came in at around 70-75kg (155-165lbs). I weigh in at 66kg (147lbs) the way my mother first clapped eyes on me, so probably under 150lbs when dressed for polite society! I'll have to dig out my notes to see what the painted weight is (not 100% sure I re-weighed it.)
I've just started work on Pilot Pod #2, which will be a composite monocoque construction using a carbon/nomex/kevlar sandwich for the hull and sills. This will eliminate all of the wooden parts (internal longerons, ribs, frames bulkheads and the heavy wooden floor/door) and make it more 'curvy'! I'll also loose the skins along the insides of the pod, exposing the control wires, levers and joystick for easy inspection, maintenance and modification. I'll keep the main foot-launch door, so it remains a Class 2/4 glider for regulatory purposes, but will modify the design significantly. I'm also shooting for a one-piece lexan canopy that will extend well forward of the rudder pedals - I found the forward bulkhead/frame at Sta 0.0" obscured my view a little. I may have to experiment with heat forming the lexan to help it conform to the compound curves. Pod #2 should be considerably lighter than the existing pod. I started working on the templates for the Pod #2 plug yesterday - it's good to be making stuff again!
